Question Help My PC keeps experiencing lag spikes
If you rule out cooling, and you are up to date on drivers and Windows updates, double check the Task Manager to see if you have any programmes that are utilising the CPU and causing high CPU usage as that can cause lags and spikes. I would also just check Start Up as well and disable any start up applications that are not required.
LinuxDevice
Respectable
May 20, 2017
358
7
1,965
64
Some games which load data at various points may have a lag spike due to disk read. Having an SSD instead of an old style hard drive can dramatically improve things if this is the case.
Reactions: vMax
Nov 11, 2019
Ok my cpu usage was at 100% when playing rainbow six siege but siege was taking up most of the cpu so is there anything i can do about that?
