Full PC Speculations:What are you full system specs? Also was this a clean install of Windows? Also do you have all your drivers up to date?
I used the same windows 10 copyWhat he meant by clean windows install is, when you added/changed components did you use the same windows 10 copy? or installed a fresh one after formatting.
Yes I definitely feel I’m underperforming and it’s really annoying when I’ve dished out thousands to feel as if I have the upper hand, when friends with subpar PC’s seem to be performing better in benchmarks, settings etc I’m not sure what’s wrongsame issue i feel like my pc is underperforming as well i dont know what to do
Oh, you meant changed components themselves like hardware? I never changed any hardware whatsoever didn’t touch it, everything is also reading properly that’s not the issue I’m just not sure what is.Well you probably should be formatting your drive and installing a fresh copy instead, that could help with your solution.
No I literally got the whole computer all together a couple days ago, every single part is brand newWell if you had your harddrive in another computer and used it in this computer, then you probably need a fresh install of windows 10.
