HELP!!! My TeamSpeak is all of a sudden not working!!!!
Luke2468
197
Hi there, ive been using teamspeak to chat with friends and just recently windows 10 had an update and now everything works but teamspeak. when i enter it at the bottom right it says disconnected and when i try to browse servers nothing happens and it says weblist server could not be connected. Ive tried reinstalling it and that doesnt even work. Please help this is very frustrating thanks for any help!
Hi,
Try to do a clean install on TeamSpeak and see if it will work.
- Open Programs and Features and uninstall TeamSpeak.
- Press the Windows key + R then type %temp% and press OK.
- Delete everything in that Window and if some will not delete just skip them.
- Press the Windows key + R then type %appdata% and delete the TeamSpeak folder.
- Right click on your Recycle Bin and empty it.
- Reboot your PC and after the reboot try installing the software again.
- Download link: https://www.teamspeak.com/downloads
Hi,
Latest posts
