Help ! My trial version of pilot2atc product is not maximizing! urgent help needed because my trial ends in 10 days!
Souvik Chatterjee
73
I recently downloaded the trial version of pilot2atc, a plugin application for x-plane 10 a simulator for pc. i installed it, then ran the app and i was shocked to find that it was stuck to the taskbar and not maximizing at all!! i tried the following:
1 : Alt+tab; Win+tab
2: regedit process of deletion
3: changing compatibility, as well as run as "maximized window" and run as admin
No success as of now.....
Additionally, i had to install the microsoft sql server 2012 local db which was needed for the plugin app. Anybody with ideas other than the ones mentioned above are welcome to reply with no prior notice. Thanks in advance
My specs: i5-4210u, geforce 820m , 8gb ddr3 ram, win 10 pro
