my 2yearold 1terabyte wd black wdcwd1003fzex-00mk2ao is failing.I run crystal disk ,disk sentinel
tryied to fix it with windows disk check fix whatever nothing 🙁 should i put the funeral music on or theres still hope?I alrerady feel the degradation in performance,steam cant download games correctly diska and network usage are irregular like waves i get disk error twice yestaerday.
P.S. Dont listen to mozarts requim if u happen to be in this situation
1,Raw Read Error Rate,51,200,200,OK,0000000032FA,0,Enabled
3,Spin Up Time,21,181,171,OK,000000000785,0,Enabled
4,Start/Stop Count,0,98,98,OK (Always passing),00000000088C,0,Enabled
5,Reallocated Sectors Count,140,137,137,Pre-Failure: Data loss predicted,000000000A86,0,Enabled
7,Seek Error Rate,0,200,200,OK (Always passing),000000000000,0,Enabled
9,Power On Time Count,0,84,84,OK (Always passing),000000002EF3,0,Enabled
10,Spin Retry Count,0,100,100,OK (Always passing),000000000000,0,Enabled
11,Drive Calibration Retry Count,0,100,100,OK (Always passing),000000000000,0,Enabled
12,Drive Power Cycle Count,0,98,98,OK (Always passing),000000000808,0,Enabled
192,Power off Retract Cycle Count,0,200,200,OK (Always passing),000000000108,0,Enabled
193,Load/Unload Cycle Count,0,200,200,OK (Always passing),0000000007C7,0,Enabled
194,Disk Temperature,0,108,95,OK (Always passing),000000000023,0,Enabled
196,Reallocation Event Count,0,1,1,OK (Always passing),0000000002A6,0,Enabled
197,Current Pending Sector Count,0,200,189,OK (Always passing),00000000007B,0,Enabled
198,Off-Line Uncorrectable Sector Count,0,189,189,OK (Always passing),00000000077D,0,Enabled
199,Ultra ATA CRC Error Count,0,200,200,OK (Always passing),000000000000,0,Enabled
200,Write Error Rate,0,195,195,OK (Always passing),00000000082C,0,Enabled
