B bigdoglee007 Distinguished Oct 17, 2011 2 0 18,510 Oct 18, 2011 #1 I need 2 dual DVI cards but am not sure which is best. Im a stock trader so i need them to power 4 monitors. Dont need anything high-end. Just need 2 solid cards. My budget is $100-$130.
geofelt Titan Oct 9, 2006 56,662 5,154 179,240 Oct 18, 2011 #2 Here is one that should do the job. You really don't need anything more than a minimal card. $30 after rebate: XFX HD-467X-ZDFR Radeon HD 4670 1GB 128-bit http://www.newegg.com/Product/Product.aspx?Item=N82E16814150579 Upvote 0 Downvote
dalmvern Distinguished Jun 15, 2011 673 0 19,060 Oct 18, 2011 #3 Well this is about the cheapest you will get and it may be all that you are looking for. http://www.newegg.com/Product/Product.aspx?Item=N82E16814130680 If you could go with two double slot cards, this one might be better. http://www.newegg.com/Product/Product.aspx?Item=N82E16814500213 Upvote 0 Downvote
B bigdoglee007 Distinguished Oct 17, 2011 2 0 18,510 Oct 18, 2011 #4 Thanks all for the help! Upvote 0 Downvote
