Help, need advice on AMD gaming rig
JB
365
Archived from groups: alt.comp.hardware.overclocking.amd (More info?)
A friend has asked my advice on a from-scratch gaming rig.
I'm strictly an Intel guy, so I need advice as to
mobo, chipset I should look at (AMD). Specifically, what are the
pros/cons of various socket types and chipsets. Also, he wants
integrated giga bit LAN and sound. A starting point seems to be
a 64 bit Athlon 3400+, but nothing is set in stone.
Thanks for any inputs.
Jeff B
You're on the right track The A64 is the best when it comes to gaming, and
most other things too.
For gigsbit lan, you probably want to look at an NF3-giga chipset with
built in gigabit lan. The 754 is the cheap route. You'll probably pay
close to double for 939 cpu's, for about a 15% gain.
Abit KT7-Raid (KT133) Tbred B core CPU @2400MHz (24x100FSB)
http://mysite.verizon.net/res0exft/cpu.htm
Latest posts
