S someone546 Prominent Apr 3, 2019 5 0 510 Apr 3, 2019 #1 i have a ECS h81h3m4 motherboard with gt 740 gpu. i want to upgrade my gpu to rx 570 but i dont know if its compatible or not
MrN1ce9uy Judicious Aug 20, 2009 6,955 639 35,890 Apr 3, 2019 #2 Yes, it is compatible with your motherboard. What power supply do you have? Be sure it is sufficient for the GPU. Last edited: Apr 3, 2019 Upvote 0 Downvote
Karadjgne Titan Ambassador Dec 26, 2012 30,740 4,559 142,790 Apr 3, 2019 #3 Gpus are basically compatible with any mainstream motherboard produced in the last 10 years or so. For a Rx570 you'll need a decent 520-550w psu. Upvote 0 Downvote
S someone546 Prominent Apr 3, 2019 5 0 510 Apr 3, 2019 #4 oh ok i will go and look for 550w psu thank you Upvote 0 Downvote
S someone546 Prominent Apr 3, 2019 5 0 510 Apr 3, 2019 #6 what if i use ddr4 2400 ram still ok? Upvote 0 Downvote
MrN1ce9uy Judicious Aug 20, 2009 6,955 639 35,890 Apr 3, 2019 #7 someone546 said: what if i use ddr4 2400 ram still ok? Click to expand... No, your motherboard only supports DDR3. Upvote 0 Downvote
