[SOLVED] HELP! need help with 144hz
Jan 21, 2020
20
I have recently built my new PC. my monitor is acer gh276hl which is 1920x1080 144hz. It has a HDMI, DVI, and VGA port at the back. I used DVI on my old PC.
My new GPU only has Display Port and HDMIs. the HDMI cable I am using only lets me use 1920x1080 at 60hz.
My Motherboard's onboard ports don't work because if the cpu not having an integrated gpu. (i7-9700kf)
Is there any compromise/solution I can make? I've heard of a higher version of HDMI that supports 144hz but I don't know if I have it.
Please see section 0 here: https://forums.tomshardware.com/threads/how-to-connect-to-a-120-hz-display.3268285/
