I have decided that I want to start streaming. I need help putting togther a PC that meets the Elgato HD 60s requirements. The requirements are
Windows:
• Windows 10 (64-bit)
• 4th generation quad‑core Intel Core i5 CPU (i5-4xxx or comparable)
• Intel HD, NVIDIA GeForce GTX 600 series or VCE 3.x compatible AMD graphics (or better)
• 4 GB RAM, built-in USB 3.x port
• Internet connection
I have tried putting some options together on Pcpartpicker but am having trouble. I thought I had a good one put together but I discovered AMD Ryzen Does not have integrated graphics.
I already have a hard drive and Windows 10, I just need help with the pc. I also plan on doing lite video editing but figure a pc with those requirements can handle that.
Thanks so much for the help
Windows:
