D ddhaedo Jul 3, 2019 2 1 15 Jul 4, 2019 #1 I lost the original .rom for my card, and it is really unstable now. I want to go back to the original .rom and need someone that can send me that. Thank you. Card is: MSI RX580 GAMINGX 8GB Samsung Memory Serial No. S/N1: 602-V341-450B1708000517
D Daveyo Distinguished Mar 17, 2009 86 1 18,635 Jul 4, 2019 #2 Contact MSI and maybe they can help you. If its a download, then you can burn it on a DVD and presto you got CD rom for your card. Reactions: ddhaedo Upvote 0 Downvote
D Deleted member 2731765 Guest Jul 4, 2019 #3 Try looking here as well: https://www.techpowerup.com/vgabios/?manufacturer=MSI&model=RX+580 Reactions: ddhaedo Upvote 0 Downvote
D ddhaedo Jul 3, 2019 2 1 15 Jul 4, 2019 #4 Metal Messiah. said: Try looking here as well: https://www.techpowerup.com/vgabios/?manufacturer=MSI&model=RX+580 Click to expand... Thank you you are the best. I found it in that lind. SOLVED!!!! Reactions: Deleted member 2731765 Upvote 0 Downvote
lux1109 Reputable BANNED Apr 30, 2019 117 25 4,610 Jul 4, 2019 #6 How did you lose your BIOS in the first place ? Upvote 0 Downvote
