[SOLVED] Help need with my build RAM
Oct 15, 2021
Hi
I just upgraded my system.
Motherboard: Asus tuf z590 plus wifi
CPU: i5-10400
Graphics: gt1060 super
RAM: corsair 2x 16GB 2666
PSU: coolmaster 650w
My issue is the system both bios and Windows recognize half of my ram either I install one unit it shown on BIOS 8 gb, I installed 2 shown as 16 gb
I tried chande the slots. Re seat CPU many time and check the pins. I dont know what is the problem Motherboard or cpu or ram itself can any o e help to trying to solve it with me
All my motherboard , cpu, ram bought as new and sealed.
Thanks alot
Thank you for your reply
I found the problem defected RRAM I took it back to the seller and change it with new onw it is working fiine now
thanks again
thanks again
