This is my first post so please bear with me.
I just purchased a LITE-ON sohd-16p9s DVD-ROM drive which i was hoping to use in conjunction with my NEC ND-3520A DVD-RW drive, so leaving my NEC set to master and setting the LITE-ON to slave on the same IDE ribbon and all connections all correct i started up my pc to find that the LITE-ON wasn`t being detected at all, though it does have power. I am on Windows XP home edition.
When i tried the LITE-ON on its own with the NEC taken out it worked just fine and it was detected, i tried the NEC with another drive and all was fine. I can`t think of what to do next.
Has anybody got any ideas on this matter because it is really puzzling me.
I have been told that the cable select method might work but having looked around on the net it looks like the 40-conductor IDE cable i have will not allow this.
Is there a way round this or do i have to buy another cable, and if so which one.
Thanks in advance.
Thanks in advance.
