Help needed for first PC build
Squall133
4
Hi everyone, I'm about to attempt to build my first computer but I wanted to check that everything was compatible and would work. I haven't bought any of the components yet so if anyone could recommend a better build that would be great :) my budget is £550-580/ $850. My main use of this computer would be for gaming.
Intel i5-4570- £156
ASRock H87 PRO4 S1150 Intel H87 DDR3 ATX- £73
http://
G.Skill 8GB DDR3 1600Mhz RipjawsX Memory- £55
http://
Seagate 500GB Barracuda SATA-600 7200RPM 16MB 3.5" Hard Drive- £40
http://
EVGA 02G-P4-3658-KR GeForce GTX 650Ti Boost Superclocked Nvidia Graphics Card (2GB, GDDR5, PCI-Express 3.0, 192-Bit)- £138
http://
XFX 550W Core Edition 80+ Bronze PSU- £51
http://www.dabs.com/products/xfx-550w-core-edition-80--bronze-psu-8K0S.html
LG GH24NS95.AUAA 24x SATA SuperMulti Internal DVDRW Bulk- £17
http://
Antec One Gaming Case Mid Tower ATX- £41
http://
Thanks very much,all advice is appreciated :)
For the same price, this is a much more powerful build which would serve you for longer.
CPU: AMD FX-8350 4.0GHz 8-Core Processor (£143.99 @ Aria PC)
Motherboard: MSI 970A-G46 ATX AM3+ Motherboard (£63.56 @ Scan.co.uk)
Memory: G.Skill Ares Series 8GB (2 x 4GB) DDR3-1333 Memory (£35.69 @ Amazon UK)
Storage: Seagate Barracuda 1TB 3.5" 7200RPM Internal Hard Drive (£43.19 @ Aria PC)
Video Card: MSI GeForce GTX 760 2GB Video Card (£195.17 @ Dabs)
Case: Zalman Z9 ATX Mid Tower Case (£32.10 @ Amazon UK)
Power Supply: XFX 650W 80 PLUS...
Power Supply: XFX 650W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply (£58.91 @ Scan.co.uk)
Total: £572.61
(Generated by PCPartPicker 2013-07-13 03:54 BST+0100)
If you think that the answer helped, then don't forget to select it as the best answer. It would be highly appreciated by me.
Hi, thanks for the advice. I forgot to mention i wont be overclocking. That build looks really good, im just a bit skeptical about the processer, I thought the i5 4570 was faster, could you tell me why you picked that processer? Thanks
Because the i5 was going above the budget and i did not wanted to go above the budget, so i selected the 8350, it is a good CPU, so you would be just fine with this CPU too. This CPU can handle the 1000 dollar titan easily, so this is just a 760.
Latest posts
