Help needed for gaming build
I would use pcpartpicker but it doesnt support my country also the main spirit of the question is
i5 4440 and gtx 960
Or
Fx-6300 and gtx 970
buying a gaming pc you are going to want the 970 its way more powerful than the 960 and will last ages if you got the 960 you would regret it because its not as good by a long shot
if you saved up for 2 weeks to get them you wouldnt regret it
