Help needed in order to upgrade my current pc
the-itch
Hello,
would like to upgrade my Compaq Presario SR5601UK.
It's current motherboard MSI MS-7525, also known as MS-7525 (Boston) Intel G31 Express my current processor Intel Celeron E1200 1.6GHz.
*Socket: 775*
Have a 300W power supply and it's a Mid-size ATX case.
Only want to upgrade my mobo and cpu, need advice asap
thanks so much
Uther39
Whats your budget and what do you use your pc for?
Uther39
OK your going to need MOBO, CPU and RAM,
SO here you go all for £220 delivered
http://www.scan.co.uk/products/msi-h67ma-e45-(b3)-intel-h67-s-1155-ddr3-sata-iii-6gb-s-raid-sata-pcie-20-(x16)-vga-on-board-micro-a
MSI H67MA-E45 new B3 stepping
http://www.scan.co.uk/products/intel-core-i3-2120-s1155-sdy-bridge-33ghz-5gt-s-hd2000-igp-850mhz-3mb-cache-core-r-33x-65w-retail
Intel CPU i3 2120 Sandy Bridge Dual Core Processor
http://www.scan.co.uk/products/8gb-(2x4gb)-corsair-ddr3-xms3-pc3-12800-(1600)-non-ecc-unbuffered-cas-9-9-9-24-15v
Corsair Memory XMS3 8GB DDR3 1600 MHz
This will be a massive upgrade for you and you will se a huge difference in speed and general performance. It will also still be within your 300w PSU ability.
Uther39
I would advise you to buy this which includes a new better PSU
MSI H67MA-E45 (B3), Intel H67, S 1155, DDR3, SATA III - 6Gb/s, RAID SATA, PCIe 2.0 (x16), VGA On Board, Micro ATX
£62.67 £75.20
£79.15
Intel Core i3 2120, S1155, Sdy Bridge, 3.3GHz, 5GT/s, HD2000 IGP 850Mhz, 3MB Cache, Core R 33x, 65W, Retail
£79.15 £94.98
£32.80
8GB (2x4GB) Corsair DDR3 XMS3 PC3-12800 (1600), Non-ECC Unbuffered, CAS 9-9-9-24, 1.5V
£32.80 £39.36
£30.43
http://www.scan.co.uk/products/430w-psu-corsair-builder-series-cmpsu-430cxv2uk-80-eff-uncertified-quiet-fan-atx-v23
430W PSU, Corsair Builder Series CMPSU-430CXV2UK, 80% Eff', Uncertified, Quiet Fan, ATX v2.3
£30.43 £36.52
TOTAL = £255 with delivery
