Help needed! MEMORY_MANGEMENT, Ntoskrnl.exe and hardware.sys BSOD
rikniesink
Commendable
Nov 26, 2017
16
Hi guys,
My pc keeps crashing and giving BSODs, I have no idea what to do about it as Im not sure of the cause. It crashes mostly when im in some kind of loading operation (in a game or starting an app), but this is not 100 percent the case.
Here is are the crash dumps:
On Mon 15/01/2018 21:23:58 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\011518-7703-01.dmp
This was probably caused by the following module: ntoskrnl.exe (nt+0x1756E0)
Bugcheck code: 0x50 (0xFFFFF803EAAAF6A0, 0x0, 0xFFFFF803F2AB4798, 0x2)
Error: PAGE_FAULT_IN_NONPAGED_AREA
file path: C:\WINDOWS\system32\ntoskrnl.exe
product: Microsoft® Windows® Operating System
company: Microsoft Corporation
description: NT Kernel & System
Bug check description: This indicates that invalid system memory has been referenced.
This appears to be a typical software driver bug and is not likely to be caused by a hardware problem.
The crash took place in the Windows kernel. Possibly this problem is caused by another driver that cannot be identified at this time.
crash dump file: C:\WINDOWS\MEMORY.DMP
This was probably caused by the following module: ntkrnlmp.exe (nt!memset+0x15E1D)
On Mon 15/01/2018 20:53:47 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\011518-7328-01.dmp
This was probably caused by the following module: hardware.sys (hardware)
Bugcheck code: 0x1A (0x41792, 0xFFFF8E002FB60158, 0x400000000, 0x0)
Error: MEMORY_MANAGEMENT
Bug check description: This indicates that a severe memory management error occurred. A corrupted PTE has been detected.
This might be a case of memory corruption. This may be because of a hardware issue such as faulty RAM, overheating (thermal issue) or because of a buggy driver. This problem might also be caused because of overheating (thermal issue).
A third party driver was identified as the probable root cause of this system error. It is suggested you look for an update for the following driver: hardware.sys .
Google query: hardware.sys MEMORY_MANAGEMENT
On Mon 15/01/2018 20:51:59 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\011518-8515-01.dmp
Bugcheck code: 0x1A (0x41793, 0xFFFF8001026FEDC8, 0x4A, 0x49)
On Mon 15/01/2018 20:50:14 your computer crashed or a problem was reported
crash dump file: C:\WINDOWS\Minidump\011518-8875-01.dmp
Bugcheck code: 0x50 (0xFFFFFE8AF055BC94, 0x0, 0xFFFFF8046C4504A0, 0x2)
Any idea what could be the cause?
My system:
ASRock A320M Pro4 motherboard
16gb corsair vengeance
SSD
R9 270X 2GB
Ryzen 5 1600
Thanks!
I did 2 passes on all my RAM with memtest once. Found nothing. Does it still makes sense? Ive also thought about updating the BIOS.
Anyway, here the link with some more info, is this enough?
https://ufile.io/sx04r
Thanks, it is my game indeed but it happens in other games as well sonI should focus on the other 2.
Any idea how to fix it?
