Question Help needed. Not sure if my graphics card is compatible with my motherboard.
Sep 14, 2020
This is my first time building my own pc and i was installing everything and it was going smooth but then i got to where i needed to install my graphics card. I have the x570 aorus elite wifi motherboard and msi geforce rtx 2060 graphics card. When i try to insert the gpu into the motherboard, it won’t fit into the slot on the motherboard. Are these two just not compatible or am i completely missing something?
Reactions: Gaming7Ray
Jun 13, 2020
58
11
45
hahahah :p:p
of course it is compatible
Check your graphics card pin and allign properly in PCIe slot
it take some force because there is a lock in pcie slot in last which get locked in GPU pins
