Hi Everyone,
I am trying to build a computer with the following components.
1) AMD Athlon™ II X2 270 - http://www.frys.com/product/6755375
2) MSI 870U-G55 AMD 770 AM3 USB 3.0 ATX AMD Motherboard - http://www.frys.com/product/6592413
3) DDR3 4GB PC1600MHz DUAL - http://www.frys.com/product/6047968
4) Coolmax 600W 140mm Smart Fan ATX Power Supply with single PCI-E - V-600 - http://www.frys.com/product/5919434
I need to connect upto 4 SATA 3.5 HDD's. Is the power supply mentioned above be sufficient enough for this? If not then what would you recommend with the lowest amount of power requirement and should work at both 115/230 modes.
Thank You
Thank You
