G
Guest
Guest
Archived from groups: alt.sys.pc-clone.dell (More info?)
I was playing with the resolution settings on my monitor. I set the
resolution to 1600x1200, 32 bit color, 85 Hz refresh rate. The
monitor promptly went into "sleep mode" (light went from green to
orange). I can't get the monitor to wake up. I checked the user
manual and found that my monitor only supports that resolution at 80
Hz, so that explains why it is going into sleep mode. My questionis,
how do I fix my monitor settings if I can't get it to wake up?
The problem occured while I was booted into Windows 98 (dual boot). I
have not been able to boot into Safe Mode. First I tried holding down
F8. When that didn't work, I tried holding down Control. In each
case, the monitor goes into sleep mode before I can tell if I'm in
Safe Mode or not. What should I do next?
Configuration:
Monitor: Iiyama Vision Master 450 19" CRT
Video: Vision GeForce 3 Ti 200
Computer: Dell XPS R 400 upgraded to a 1 GHz Pentium III, 512MB Memory
OS: Windows 98 / Windows XP Dual Boot
Boot Mgr: Boot Magic
Thanks,
--WB
Configuration:
Thanks,
--WB
