Help Needed with CPU Cooler
sayems
28
Hello,
I am trying to find the perfect CPU cooler that would fit on Asus P5E / Antec 900 without doing any moification of removal, I’ve been searching for which cooler would fit in the Antec, so far I have got the Thermalright Ultra 120, Thermalrights IFX-14 and Tuniq Tower 120 will not fit without removal or modification of the side panel, I was considering the ARCTIC COOLING Freezer 7 Pro 92mm CPU Cooler or ZALMAN CNPS 9700 NT 110mm 2 Ball Ultra Quiet CPU Cooler but I can't find any usefull information whether it fits my case or not. I was wondering if anyone has any suggestions for a good CPU cooler for my PC. Thanks you in advance.
Supposedly they do fit. I'm getting a TR120 because with 2 high power fans it's just as good/better than the IFX-14 with 4 fans.
I'm putting it horizontally with exhaust through the 200mm top
ZALMAN CNPS 9700 NT will fit... It is huge,, but will fit Antec 900..
Installation is a little tricky... Make sure you have someone else to help you ...
Install it with the fan facing the front of the case...
Mine runs at a max of 2890RPM.... My Quad-Core runs between 30-35 C
