Hello everyone!
So I've wanted a proper gaming rig for a while to replace the Dell office computer I'm currently using.
Here's my parts list: http://uk.pcpartpicker.com/p/DNtTK8
I've already bought the case, hard drive, SSD, power supply, motherboard and RAM, so I can't really change those.
I'm on the fence between the R9 390 and the GTX 970, but I've seen that 390 eats more power, and since I don't want to buy another PSU I'll most likely go with the 970. Would I need more than 600W of power with that build if I got the 390?
Also, would I need any more fans than the two 120mm ones the case came with? If yes, what 120mm would you recommend (preferably around £15 or less/fan)?
I'm not planning to overclock.
Thank you very much in advance!
