Hi!
Got great advice from this forum for my old build 8 years ago, so I'm back again hoping for help with a new build!
My old system is starting to feel a bit slow in workstation mode, also video editing is far from a breeze. And I want to get something with WIN11 compatibility.
Looking to build a new system either from scratch or using current case + PSU.
My usage is 95% workstation with some video editing and 4K video playing. Some light gaming also.
I'm currently running this build:
Intel i5 4570
16GB Crucial Ballistix Sport DDR3-1600 DIMM CL9 Dual
Gigabyte H87-HD3 Intel H87 So.1150 Dual Channel
ASUS STRIX-GTX980-DC2OC-4GD5
Fractal define R4
24" (60,96cm) Dell UltraSharp U2412M
730 Watt be quiet! Pure Power L8 CM Modular 80+ Bronze
I have a possibility to get a used 1080ti for not too much money. I think this card might be a good fit for my needs.
Also on the wishlist:
-really good 24" screen
-quiet build (but no water cooling etc. stuff)
-32gb of RAM
What would you say about the 1080ti card and what components would be best bang for buck? Budget around 1000€ + what ever the 1080ti costs.
Thanks in advance!
Intel i5 4570
Fractal define R4
-32gb of RAM
Thanks in advance!
