• Hey there, Guest! Share your idea for a new trophy in the forums and win bragging rights and a $100 Amazon gift card! Check out the New Community Trophy Contest here!
  • Pardon our dust as we work on some regularly scheduled forum maintenance. You may notice some missing features during this time. Thank you for your patience!
Help needed with Remote Desktop and SP2
Simon
415
Archived from groups: microsoft.public.windowsxp.general,microsoft.public.windowsxp.work_remotely (More info?)
Hi,
I have XP pro SP2 and I am trying to connect remotely to my PC, (I also have
Zone Alarm Pro).
At first I could not connect because I thought it was ZA that was at fault
but then, after turning off both firewalls, I realized that the XP firewall
was blocking.
I simply cannot connect with the Windows firewall on.
Under the advanced settings I checked "VPN L2PT", "VPN PPTP" as well as
"Remote desktop".
But I still cannot connect.
Looking around google it appears that I have to allow a certain port in my
exceptions, but what port number is that?
The error I get on the other computer when I do http://ww.xx.yy.zz/tsweb is
simply a "Cannot find server".
If I disabled the XP firewall it works like a charm.
Any idea? I just don't want to turn my firewall off when I go to work.
Many thanks
Simon
Simon
415
> Many thanks
> Simon
Ok,
I fixed it, and much to my embarrassment it was my fault all along.
I thought I had installed remote access on the Win98 machine but I hadn't
really.
So after a quick install I got it running just fine with both ZA and WinXP
firewall.
For the record the Advanced tab didn't have remote access allowed and that's
why it was not working with my Work Xp machine.
But even allowing remote access was not working because it was not working
properly.
I am not sure why it was working with the firewall totally off.
Many thanks
Simon
G
Guest
Guest
"simon" <spambucket@myoddweb.com> wrote in message
news:urCYSaVIFHA.2564@tk2msftngp13.phx.gbl...
> Hi,
have
> Zone Alarm Pro).
firewall
> was blocking.
> "Remote desktop".
is
> Many thanks
> Simon
The simplest way would be to open port 3389 on your firewall,
and to set up your router (if you have one) to forward port 3389
packets to your PC. If you do it like this then you won't need
a VPN.
Simon
415
> is
>> Many thanks
>> Simon
> a VPN.
Thanks, but that does not work.
Under the exception there is already an entry "Remote Desktop TCP 3389" and
for a test I added UDP but that made no difference.
Simon
G
Guest
Guest
news:e%23h%23uvVIFHA.1996@TK2MSFTNGP12.phx.gbl...
>> is
>>> Many thanks
>>> Simon
>> a VPN.
> and for a test I added UDP but that made no difference.
> Simon
Scope = Any ?
Simon
415
>>> a VPN.
>> Simon
> Scope = Any ?
Yes, Scope=Any.
And under 'Advanced' I cannot edit the port number, it is 3389 by default.
Simon
G
Guest
Guest
"Simon" <spambucket@myoddweb.com> wrote in message
news:38tbf3F5no2ghU1@individual.net...
>>>> a VPN.
>>> Simon
>> Scope = Any ?
> Yes, Scope=Any.
> Simon
How to change the listening port for Remote Desktop
http://support.microsoft.com/kb/306759/EN-US/
William
Simon
415
> William
Thanks, but the problem seems to be something else.
Even with port number 3389 open it does not work.
If I shutdown the server it works, so I guess something else is blocking.
Maybe RD is not listening on port 3389, so opening that port is useless.
So I guess that changing the port number would not help really.
Simon
G
Guest
Guest
news:38td4vF5s2ormU1@individual.net...
>> William
> Simon
Are you port forwarding the port to the IP address of the computer you want
to connect to?
William
Simon
415
> want to connect to?
do you mean http://ww.xx.yy.zz:3389/tsweb? if so then yes, i tried that and
it does not work.
I also tried without of course and it also does not work.
Again, as mentioned, it all works fine with MS Firewall disabled.
> William
Simon
G
Guest
Guest
news:OUGBcoWIFHA.3472@TK2MSFTNGP09.phx.gbl...
>> want to connect to?
> and it does not work.
>> William
> Simon
No I do not mean that. Are you behind a router? Or just a server? Once I
know this I can explain.
William
Simon
415
No, i am not behind a router.
> William
Simon
G
Guest
Guest
news:uoJ5dtWIFHA.2648@TK2MSFTNGP14.phx.gbl...
>> William
> Simon
How to manually open ports in Internet Connection Firewall in Windows XP
http://support.microsoft.com/default.aspx?scid=kb;en-us;q308127
William
Simon
415
> William
Like I mentioned, opening the port does not seem to work.
I am not sure if the port number is even correct.
Port 3389 might be open, but it does not allow RD.
Port 3389 might not be the right port.
Is there a way to test what port RD is listening on, that might actually
help to see if that's the problem?
Simon
G
Guest
Guest
news:38th7fF5sqri9U1@individual.net...
> > William
> Simon
You never told us how you connect to your outside world.
All we know so far is that you do not use a router.
The easiest way to trouble-shoot such problems is to start
from the inside: Use another PC to issue this command:
telnet aaa.bbb.ccc.ddd 3389
where aaa.bbb.ccc.ddd is the RDP host. Once you
get the host to respond, you can extend your tests to
the outside world.
I assume that you have Remote Desktop enabled on
your RDP host.
G
Guest
Guest
In addition there is some troubleshooting help on this page..
http://theillustratednetwork.mvps.org/RemoteDesktop/RemoteDesktopSetupandTroubleshooting.html
Al Jarvi (MS-MVP Windows Networking)
Please post *ALL* questions and replies to the news group for the mutual benefit of all of us...
The MS-MVP Program - http://mvp.support.microsoft.com
This posting is provided "AS IS" with no warranties, and confers no rights...
"Pegasus (MVP)" <I.can@fly.com> wrote in message news:eD0UeNXIFHA.2924@TK2MSFTNGP15.phx.gbl...
>> > William
>> Simon
> the outside world.
> your RDP host.
Simon
415
Sorry, I didn't know it mattered because I did mention that it worked with
windows firewall off.
BTW, I might get in trouble for mentioning that so late, but I am using win
98 as my other machine, (that's the only one I have).
But seen that it works fine without the firewall I can only assume that it
should work with it.
With or without the firewall I get the telnet screen, (it seems ok). But
after around 40 sec I get "Connection to host lost"
I can ping my ip address, (without the firewall of course).
> the outside world.
I am not sure if the response I get is a success or not.
> your RDP host.
Yes, (System->Remove->"Allow users...")
Simon
G
Guest
Guest
Going back to your original post...
Why are you running with both ZA Pro and the Windows SP2 firewall on the same PC? Turn off the
windows firewall and only use ZA Pro...
"simon" <spambucket@myoddweb.com> wrote in message news:eV5eHqXIFHA.1476@TK2MSFTNGP09.phx.gbl...
> Sorry, I didn't know it mattered because I did mention that it worked with windows firewall off.
> BTW, I might get in trouble for mentioning that so late, but I am using win 98 as my other
> But seen that it works fine without the firewall I can only assume that it should work with it.
> With or without the firewall I get the telnet screen, (it seems ok). But after around 40 sec I get
>> the outside world.
>> your RDP host.
> Simon
Simon
415
> same PC? Turn off the windows firewall and only use ZA Pro...
It looks like I will have to do that :(
I just wanted to understand why ZA can allow the connection while WinXP does
not.
I am guessing that there is something blatantly wrong in my setup somewhere.
Simon
G
Guest
Guest
"Sooner Al [MVP]" <SoonerAl@somewhere.net.invalid> wrote in
news:OZrjY3XIFHA.2924@TK2MSFTNGP15.phx.gbl:
> the same PC? Turn off the windows firewall and only use ZA Pro...
thats the best answer i heard all thread
Similar threads
