First of all i need to explain that i do not know what the problem with my new pc is, so i cannot choose which category to put this question in. With that said, here is what happened.
So i came home yesterday and turned my pc on, and it turned on..... but nothing happened. so i turned it off and back on, and everything was fine.
Then today i leave for work and turn off my pc using the windows shut down (i did not press any buttons on the case to turn it off.
Then, when i came back from work today i turned my pc on using the front case power button, as i have done many times before.
But this time the same problem happened. So i tried turning the pc off using the front power button and nothing happened. Then i turned it off using the back power switch.
Then i tried turning back power switch on and pressing the front power button..... But still nothing happened? I tried this countless times and nothing happened.
And there are no "beeping" sounds when the pc is turned on.
I also tried pressing the cmos button at the back of the pc.
The troubleshooting code leds show 00 and nothing else, it does not change when i turn it on.
Side notes; There is power going to the gpu, and the cpu fan cooler as i can see the led lights turn on, the cpu itself, and ram and possibly other components i am unsure of, as i do not know how to "visually" confirm if they turned on or off.
This is a new pc i have built myself and cost $3,000 AU. I have been using it for the last 2 months or so and nothing like this has happened before.
Please help, i cannot afford to build a replacement.
The specs are;
AMD - Ryzen 7 2700X 3.7GHz 8-Core Processor
Gigabyte - X470 AORUS GAMING 7 WIFI ATX AM4 Motherboard
Corsair - Vengeance LPX 32GB (2 x 16GB) DDR4-2400 Memory
Samsung - 850 EVO-Series 1TB 2.5" Solid State Drive
Gigabyte - GeForce GTX 1080 8GB G1 Gaming Video Card
GamerChief - HYVE ATX Full Tower Case
Corsair - 1000W 80+ Platinum Certified Fully-Modular ATX Power Supply
Pioneer - BDR-209DBK Blu-Ray/DVD/CD Writer
Microsoft - Windows 10 Pro 64-bit
The specs are;
