Hi,
iv built a new pc:
500w ocz psu
AMD Phenome x4 955 3.2ghz BE
8gb ddr 2 ram
AMD2+ Matx mobo
Windows vista 64 bit (latest bios and drivers)
1tb Samsung HDD Sata
(http://www.ebuyer.com/product/141930/show_product_overview) DDR Ram Infomation.
Basically the computer just crashes very very randomly, and when it crashes somtimes its the BSOD and somtimes the screen just refreshes its self and if there is music on it will loop on the spot. i Have crash dumps ect but i havnt a clue what to do with them. I Thought it might be heat issue but i played virtua tennis for around 4 hours, Football manager for like 5, ran numerous pc mark tests and the temps seem fine. Iv updated the onboard 8300 driver, sound chipset etc.
I Done a memory test, ran if for like 4 hours and at 5% it had like 10 red lines of errors so guess the problem is there??
i havnt set the timings etc, i havnt done on any previous build and am not to sure how to, the bios is AIM.
any help be much appriciated.
iv built a new pc:
500w ocz psu
8gb ddr 2 ram
AMD2+ Matx mobo
