GTX 690
i5-3570k
16gb RAM
Asus Z77 LK
OCZ 850w PSU
Per the title that is the issue I'm having. I've narrowed down the issue substantially. Everything is plugged in properly, all powered and everything.
Integrated graphics do work, I get some screen about system needing OS repair or something weird like that. Never installed Windows so it's probably just detecting there is no OS.
Through the GTX 690, I get no monitor signal. I have switched it to a different PCIE 16 slot, and also switched the cords and rail on the PSU. No luck. Card does get lit up, and fan spinning.
So this may be an issue with the GPU or MOBO.
Does anyone have a suggestion? Is there a chance that installing Windows through the integrated gfx, could allow the 690 to activate monitor?
Thanks!!!
i5-3570k
16gb RAM
Asus Z77 LK
OCZ 850w PSU
Thanks!!!
