HELP, New build, No display
Ivan_92
Hi People, I've just did a New Build, and I suspect that the MoBo (MSI H110I PRO AC), does not have the current BIOS version, 3.7, and can not support the i5 7600 (Kaby Lake), which I confirm is compatible according to MSI. As everything works (fans spinning, HDD making noises, LEDs are on, GPU and PSU fans also good), and I tried every single tip, swaping ram, using one by one, no GPU, CMOS battery, i also jumped that, checked the socket pins, checked front panel connectors, everything you can imagine, and NOTHING HAPPENS, is it possible to update the BIOS without a Skylake cpu and without anything on the display?
PS: I don't have cd/dvd drive and was wondering if a USB can work
Thank you for reading, any comment is helpful.
Sure!? please, tell me how???
Sorry, I forgot to tell you that I've tried on every single video output with all type of working monitors, now I'm using HDMI and that's why I'm asking for the Update, is the last resource i have, if that work, the mobo is fine, if not, is trash.
