[SOLVED] Help! No display on GIGABYTE B550M DS3H AC mobo build system
Mar 12, 2021
4
Hi, I just borough following components for computer I just build.
When I turned on computer everything seems to working, all fans are running, but there is no signal to monitor.
I don't have GPU so my monitor is connected to mobo hdmi or dvi.
The mobo spec said it support following memories:
Support for DDR4 4400(O.C.)/ 4000(O.C.)/ 3600(O.C.)/ 3333(O.C.)/ 3200/ 2933/ 2667/ 2400/ 2133 MHz memory modules
My memory is DDR4 3600MHz.
I install memory to A2,B2 bank as suggested.
I try connected monitor to either hdmi or dvi but no signal to monitor.
Please help.
Thanks.
  • GIGABYTE B550M DS3H AC AM4 AMD B550 SATA 6Gb/s Micro ATX AMD Motherboard
  • Crucial Ballistix 3600 MHz DDR4 DRAM Desktop Gaming Memory Kit 16GB (8GBx2) CL16 BL2K8G36C16U4B (BLACK)
  • AMD RYZEN 5 3600 6-Core 3.6 GHz (4.2 GHz Max Boost) Socket AM4 65W 100-100000031BOX Desktop Processor
  • Intel 660p Series M.2 2280 1TB PCIe NVMe 3.0 x4 3D2, QLC Internal Solid State Drive (SSD) SSDPEKNW010T8X1
  • EVGA 750 B5, 80 Plus BRONZE 750W, Fully Modular, EVGA ECO Mode, 5 Year Warranty, Compact 150mm Size, Power Supply - 220-B5-0750-V1
Mar 12, 2021
4
I don't have graphic card yet (still looking for one). So I am just connected to on board hdmi or div.
Does motherboard has basic graphic to use on board hdmi or div?
Mar 12, 2021
4
The motherboard spec said:
Onboard Video Chipset Integrated in the 3rd Generation AMD Ryzen with Radeon Graphics processors:
Is this mean Ryzen must have igpu to use onboard video connection?
