My monitor keeps displaying no dp signal from your device, even after I changed the PSU.
I have an rtx 3060ti and a master cooler v3 elite 600w, I started noticing static electricity some time ago whenever I touched the PC and some USB ports kept working then stopping, and so on continuesly. The first time the no dp signal message showed up I unplugged and plugged some ram sticks and it worked, now it doesn't work at all. I changed the PSU to EVGA 700GD 700w 80+ gold and the issue still there.
I tried changing the GPU, and used an rx460 instead (less demanding GPU) and at first it worked, and the message disappeard, so I thought the issue is probably with the PSU and changed the PSU to EVGA 700GD, then tried hooking up the 3060ti again but the message appeared again, so I thought the issue could be with the GPU then, but when I tried hooking the rx460 again (to both the new and the old psu) this time it didn't work!!!
The dpi message showed up again even though it was working before!
I thought maybe the rx was broken somehow and used it in another old PC and it worked!
So it's not broken!
I also noticed the cpu fans keeps turning on and off while the monitor is showing the no dp message.
(This happens whenever the rtx 3060ti is hooked up, with both master cooler elite v3 and EVGA 700GD psu, BUT NOT with the rx hooked up, the dpi message is still there but the cpu fans doest turn on and off!)
I tried resetting the BIOS and CMOS but it's still not working.
And just to put everything out there in case it might help, I remember trying to update the BIOS with gigabyte windows @bios app but it didn't work, it resetted my PC but nothing happened and it didn't update, and the PC kept working normally afterwards for a while until the dp message started showing
Also I noticed that the motherboard (gigabyte b450m ds3h) have an orange light that flickers when I long press the power button to turn off the PC (which doesn't turn off) and stays still when I don't long press the power button.
And that the ram sticks light up when I plug the PSU cable into the PC, even when I still haven't turned on the power button!
And it keeps lighting until I press the power button, otherwise it won't stop.
Could a failed BIOS cause this?
And if so, why did the display work with the rx460 before and now it doesn't want to?
I'm truly lost at what the issue is.
Your help would be hugely appreciated 🙏
These are my full PC specs:
Case: Gigabyte c200 glass
CPU: AMD Ryzen 7 3700x
GPU: MSI Gaming X RTX 3060ti
Motherboard: Gigabyte b450m ds3h
Ram: Crucial Ballistix 32gb (4x8) ddr4-3200
HD: Western digital 2tb
SDs: Western digital 480gb ssd + Crucial p3 nvme m.2 1tb
Power supplies I used:
Cooler master elite v3 600w (white)
EVGA 700GD 700w (80+ gold)
I also have some rgb light fans hooked up.
So it's not broken!
