I'm trying to install my Noctua NH-D14 to my Asus Z87-Pro motherboard. The issue I'm encountering is when I try to screw the tower into the the brackets. I can't get them to catch, even when adding a lot of pressure. If I tilt the tower to one side, I can get that screw to catch but I won't be able to get the other from it being uneven. It's almost as if the screws on the brackets are too short. Help!
Pics: http://imgur.com/a/CalR5
