Hello, I have a Gigabyte GA Z170N Gaming 5, and it only comes with one CPU fan header and one System Fan Header. They are both 4 pin fan headers. When I plug in my CPU Coolor (Corsair H105), it uses the CPU fan for the pump, and the System Fan is connected to the two Fans on the radiator using a Y connect. This means all my Fan Headers are used.
So I have the Radiator in the Front, and the Fans blowing into the case past the Radiator, but I have no other Fans left. It's a Corsair mini itx 240 case. Do you think I need another Fan to evacuate the hot air or is the two fans in the radiator enough?
If I need more Fans, whats the recommended way of doing it? Should I get a PWM header and plug it into the System Fan Header on the Motherboard, then the other Fans into the PWN header? I've never used a PWM header before.
Thanks.
Thanks.
