Help!Nvidia settings are not availabe.You are not currently using a display attached to nVidia GPU.
Nikolai Gerginov
So my problem is after i install drivers,when i restart my monitor is shuting down.I need to disable the driver and run the default one.So is the problem coming from my monitor or there is a fix and i don'y know it?My monitor is a old one .( iI think is a CRT but i'm not sure.It's fat as box...on the monitor says it HP71).
So here are my specs.
Nvidia 7300 GT
Intel Pentium 4CPU 3,40 GHz.
2GB RAM
OS : Windows XP
Also in the System tab it says this :
A Physycal extension of
Please help.I can't play any video games because of this :(
Nikolai Gerginov
No.I tried that a while ago.First i installed 307 WHQL driver and it was the same.Then i tried the 192 WHQL driver and it was also the same...Also i tried to put out and back in my video card .Then i tried to re-install windows a couple of times.It's still the same all after that... :( .
