Hello I was wonering if I could get some help on if I should O.C and if I'm doing is the right way.
Here is my PC:
i5 3570k 3.5
ASRock z77 Pro 3
Corsair H60 Water Cooler
Kingston HyperX 8GB 1600 RAM
Crucial M4 SSD 128 GB
Seagate barracuda 1TB 7200 RPM
Gigabyte GTX 760 4GB
Corsair 300r Tower
Corsair 750W PSU
So here is my PC temps on 100% load using prime 95 for about 6 min maybe more (I used hwmoniter and realtemp for the temps)
overall package was at 68 degrees
Then I went to my bios and not sure what to change for OC when to the most reasonable thing and changed the "Load Optimized CPU setting" and changed it form "Disable" to "Turbo 4.0"
After that I went back and did the same thing running my pc on 100% load using prime95 and temps with hwmoniter and realtemp and heres what i got
its kinda high being at 75 degrees for an H60 cooler. I'm not sure why I get high temps its not hot in my bedroom and its not the thermal compound because I had just recently re-did it and cleaned out all my fans etc. Please help me figure out if I can go higher is it safe or should i just go to 4.0 all help is appreciated. any questions feel free to ask
Here is my PC:
i5 3570k 3.5
ASRock z77 Pro 3
Corsair 300r Tower
Corsair 750W PSU
