OK, so I am trying to OC my old E6600 but am running into a few road blocks. I guess I should post my system info first.
Mobo: Gigabyte P35C DS3R rev 1.1
CPU: C2D E6600
RAM: Crucial Ballistix DDR3 1333 7-7-7-24 @ 1.65V rated
Video: ATI HD 5770
PSU: OCZ 720 W
I suppose thats all that matters really
For cooling I have a swiftech porcupine style cooler with a 92 mm silverstone fan (80mm holes), a 92mm case fan blowing directly onto that, another 92mm side fan about where my video card is, 2 120mm case fans (front and back) and the 120mm in my PSU, all of this is in a mid tower case, all cables out of the way.
As of right now I have it up to 333FSB x 9 for 3.0 GHz, running my voltages at 1.375 set in bios, 1.33 idle in windows, 1.31 under prime 95 load. system is stable from what I can tell (have not done an extended prime bench yet), temps peak at about 60 under prime 95 (just under)
My goals for this OC: 3.2 GHz in the way of 400x8, dropping the multi down 1 from 9 as i doubt 3.6 is achievable and I would like to run my ram at 1:2 for a speed of 1600MHz.
From where I am now I tried dropping the multi to 8 and incresing the FSB to 344, I figured this is a small increase, but I lose system stability here, tried to increase my Vcc to no avail. What is next? I have tried +0.1V in my FSB and MCH (I know 0.1 is a bit much but it is the smallest increment my BIOS allows!) also to no avail. I am running the latest bios revision as well.
If it makes any difference I had this same OC rock solid in windows XP but I installed windows 7 64 bit last week and ran into some serious stability issues when I did without changing any OC settings. Also, the chip in question is an E6600 which I got the day of the release, so it is going on 5 years almost now, that entire 5 years was spent at stock speeds.
CPU: C2D E6600
Video: ATI HD 5770
PSU: OCZ 720 W
