Question HELP OC MY aorus b450m with a 2600x at 4.10ghz
DREDKNOT_2077
142
Im currently running my Aorus b450m with a 2600x an have recently OC'ED from 3.8 to 4.10ghz with a dynamic vcore offset at +.245 an dynamic soc at auto is that too much or too little ?
an wither or not it is on my linux pc what the best cpu benchmark test to run to check stability my current one i use is s-tui an is ther a way to set the stress options to get best result ?
What are it's temps under a load? (was an offset required for stability?)
CPU-Z/bench/stress CPU is roughly a 95% load, a little more stressful than most games, but, normally a few degrees below that of Prime95/small FFTs(no AVX/AVX2, which is one of the defacto standards for 'will my CPU remain stable at this clock speed' struggles)
at load after an 1hr my arctic freezer 2 120mm holds my 2600x at 58 - 60c in a 72deg room with an during a stress run some minimum stutter an micro freezes an few secs every once in a while
tho my concern is at idle while using browser an music player an any pix editing like krita i get more noticeable stuttering an micro freezes
i dont know if i could be related to my ram as its 2 sets of Crucial Ballistix 3200 MHz DDR4 DRAM Desktop Gaming Memory Kit 16GB (8GBx2) CL16 BL2K8G32C16U4W (WHITE)
with xmp enabled at 1.35volts with auto timing unless you can suggest better Manuel timings i should try
