Help OC my E8500 Rig
aceswild
5
this is first computer i have built and i wanted to know i should set things at to OC
ASUS P5Q3 DELUXE
Core 2 Duo E8500 3.16ghz
Radeon HD 4870 1 GB
CORSAIR DDR3 SDRAM DDR3 1600
Zalman CNPS9900
Corsair TX 750W
any help would be appreciated
Crashman
Polypheme
Former Staff
My E8500 needed 1.35 to get to 3.80 GHz at 400 MHz FSB. I had it running faster, but the thing became intolerant to higher voltage levels as time went by. It was an early sample and had a crappy core.
Recently-purchased E8500's will likely have the latest core and do around 4 GHz at only 1.25V. Keeping the voltage low is a great way to avoid the "voltage intolerant" problem my first E8500 had.
You should put the system together and run CPU-Z to let us know what core revision you have.
aceswild
5
i want to go 3.6-4.0 but i rather be more cautious i dont want to mess up my computer and how do i find the voltage i should use is it just trail and error?
eagles453809
229
pretty much. a good overclock for you would be 400x9.5 that will give you 3.8ghz. it should do that around 1.3vcore. use intel burn test for stability. if it passes 10-20 runs of IBT then go for a 24hour prime run.
Crashman
Polypheme
Former Staff
If you want 4.0 GHz I'd try 1.35V at 421 MHz FSB and see if it works first.
aceswild
5
in terms of temp what should i be avoiding whats a good temp when idle and when im gaming and by OC will the cpu last me 3 years with the increase temps
