[SOLVED] Help OC with diferent ram's sticks 2666 and 3200 ( stuck at 2133)
KenshiroHnK
Commendable
Nov 23, 2016
25
So thing is im trying to at least reach 2666 with both cards also tried to 2933, 3200, 3000. Any change i make on bios wont post, restarts 4 times and resets to 2133
What i did: frim gigabyte bios latest version al drivers updated. Tried first using xmp, then manualy changing volts to 1.35 1.3 1.36 and 1.4 and soc adding +252 so it gets 1.2v (base 0.8x) nothing worked also tried oc cpu base 3.2 to 3.8 and it worked.
note: rams are in chanel 2 and 4 ( and im trying to sell adata one so i can buy another gskill to fit)
PC
ryzen 7 2700
ax370 gaming k5
vega 64 asus strix
hdd wd black 2tb
nzxt 700w
Ram: 1 Gskill trident z rgb 8gb 3200mhz + 1 adata d40 xpectrix 8gb 2666mhz
jimmysmitty
Polypheme
The odds of getting them to match are going to be very difficult. They are completely different manufacture using different memory chips and timings. XMP wont work because of that. Your best bet is going to be trying to set the frequency and voltage and timings but it will take some trial and error to try and get them to both be happy with the timings.
Reactions: KenshiroHnK
