Hi, im really new to overclocking, and as i built up my specs to a decent oc system i thought i would give it a bash. I started by using the Auto OC feature of this motherboard, but the more i looked into OC'in i found that manual oc is much better. I currently have mine set to 265x9 on a 800MHZ HT Link, i havent touched ram timings all i know is that it is set to 166MHZ. Now this isnt running fully stable but the best i can get to so far, im not sure if its my GFX card causing the crash or the OC yet. here is a screenie of my CPUZ and GPUZ.
http://img.photobucket.com/albums/v174/FyreX/CPUZ.jpg
Now the problem with the X1950XT (Sapphire 512mb version) seems to be 2d/3d switching as i crash playing 3D games, and running 3DMark benchmarks, i currently havent managed to run a full one as i have started OC'ing, alough i had this problem before i even started OC'ing and thought it was my PSU that was the culprit, but i purchased a corsair PSU with sufficient amp (44) going through the 12V rail. If its any help im using 0710 BIO for this motherboard and my other components are listed below, as i said im really new to overclocking so if you could put it as simple as possible if you have any advice on what i should do to get a nice stable OC on this system and maybe get my GFX problem sorted i would class you as a geniuse . Thanks in advance.
Asus A8R32 MVP Deluxe
AMD X4200+ ( 265x9 ) 800MHZ HT Link
Corsair XMS 3200 (2x1GB)
Sapphire X1950XT(512mb version)
Corsair VX 550W PSU
Artic Cooling 64 Heatsink.
Corsair VX 550W PSU
