Help on a cheap build
Nicolo_2
5
Hello tech fans , so today I have a build for you . I am planning to buy a cheap pc for my best friend that can handle first of all cs go ( at ~120 fps )but also some other games at decent framerates (open world / racing games) so here are the maincomponents (all used ) :
-CPU Intel Core 2 Extreme qx6700
-GPU GTX 690
-Ram : 8gb ddr3
My first question is about the motherboard which one should I go for that supports ddr3 ? The second question is the psu (wattage) .The third and final question is about if for less price something better can be done.
Thank You
Here's the rest of the build, provided you already have CPU, RAM and GPU.
CPU: Intel Core 2 Extreme QX6700 2.66GHz Quad-Core Processor (Purchased For $0.00)
Motherboard: Gigabyte GA-G41MT-D3 Micro ATX LGA775 Motherboard ($68.28 @ Amazon)
Memory: G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1066 Memory (Purchased For $0.00)
Storage: Toshiba 1TB 3.5" 7200RPM Internal Hard Drive ($47.89 @ OutletPC)
Video Card: Asus GeForce GTX 690 4GB Video Card (Purchased For $0.00)
Case: Zalman ZM-T1 PLUS MicroATX Mini Tower Case ($28.99 @ SuperBiiz)
Power Supply: SeaSonic S12II...
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply ($49.90 @ B&H)
Total: $195.06
Generated by PCPartPicker 2017-03-16 09:16 EDT-0400
Few words.
Went with cheap parts while still having good build quality.
Note: PSU is fully wired. For extra $17 you can get semi-modular PSU to ease with cable management.
As far as gaming on it goes, don't get your hopes up. While GPU is decent one and you have plenty or RAM, the CPU shows it's age and may not keep up with the latest games. To put it short, you might bottleneck the CPU.
