Help on a external sound card
tachra
30
I have a problem with my laptop's soundcard that it can not be solved easily and i dont wanna make it worse ... so i wanted to buy an external sound card i was gonna buy one of these:
http://us.store.creative.com/Sound-Blaster-XFi-Surround-5.1/M/B0017QQQAE.htm
http://us.store.creative.com/Creative-Sound-Blaster-XFi-Surround-5.1/M/B0044DEDCA.htm
the thing is i dunno whats the difference between them actually?????
which one should i buy?
they seem pretty much the same....
does any of you guys know any better external sound card?
If you are not an audiophile, you can buy one of those £1 USB sound cards from eBay as they are not too bad (they sound like laptop sound cards.
Hello there,
it has a physical issue with headphone jack which after one time i put a headphone to it something happened to its port so that laptop always think a headphone is plugged in (something stuck in there)
I went to company for 2 times and they could not fix it completely
i dun wanna argue about it i need an external anyways which one is discontinued?
Latest posts
