Help on a psu?
brent3323
Any suggestions on a psu for my build wattage/ rails?
Specs....
Cooler Master:Haf 922 case...will be adding the 200mm side fan
Foxconn: P9657ab motherboard
Cpu:Q6700 most likely or 6600...not sure yet
Heatsink:Arctic Cooling Freezer 7Pro
Memory: OCZ 4GB (4 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400)
Graphics: 2x Crossfire Vision Tech Radeon Hd 4850's
Cd/Dvd: Sony Optiarc 24X DVD/CD Rewritable Drive SATA Model AD-7240S-0B -
Card reader: Nippon Labs ICR-BB All-in-one USB +eSATA
I have been considering something that can last another build or 2 such as the new ENERMAX Galaxy EVO 1250W ATX12V / EPS12V SLI Ready CrossFire Certified 80 PLUS BRONZE Certified Modular Active.
But is the $300 price worth it??
Or else something From Thermaltake or Ozc... they seem to be trusted brands.
Thanks for any help
^+1. Agreed. OP, do you really need modular cabling? You can get a non-modular Corsair with higher amps/watts (to enable CrossFire/SLI for the future) such as the 750TX for cheaper. You have more than enough space for cable management in that case.
Also, swap the Freezer Pro to a XIGAMTEK S1283, better performance for about the same price. Make sure you get the bolt in kit for it.
Thanks for the input & this will be the psu i will go with
