Help on build
Skittlz
8
Hello once again... i have finally decided what to get and i wanted feedback before i order. my parts are:
Kingston 8GB(2x4G) Kit 1600Mhz DDR3 cl10 Fury RED Ed
Intel I5-4690,3.50GHZ,4CORES,6MB CACHE,LGA1150
Sapphire R9 280 3GB GDDR5 Dual X OC version
ASUS PCE-N15 WLAN PCI-Express N300
ASRock Fatal1ty Z87-Killer
Cooler Master Storm Trooper Black Case w Windows
Corsair 750 Power Modular Supply, 80 PLUS Bronze Certified,
Samsung SATA Black Internal DVD RW Drive
Western Digital Blue 1TB
Cooler Master Hyper 212 EVO w
Transparent 12cm
thanks for reading and if you can leave feedback 😀
*Edit* This Pc will be for rendering and high caliber gaming (Do you think caliber is a stupid description of high quallity?)
-Skittlz
My suggestions are either you change that 4690 to a 4690k and get a Z97 board, or you drop the Z87 and CPU fan and go to a H97 mobo. Also get XFX 550 or a 650w PSU. 750w is overkill for that build. Otherwise everything is great here.
