Help on build
DuDeWithTheC00L
6
Hello I have 2 builds one that is more expensive and the other cheaper
Expensive:http://pcpartpicker.com/p/gtNnhM
Cheaper:http://pcpartpicker.com/p/9RfrsY
Is it worth buying the more expensive or should I stay with the cheaper one?
The higher end one will keep you happier longer, though the Corsair PSU is a poor choice (uses low end caps), and doesn't make sense to go 1x8GB 1600 when you can get 2x4GB at same price that will allow dual channel
IMHO get the cheaper one because you don't want to sacrifice half of your SSD space just for overclockability on the CPU. Also, why don't you go for the corsair PSU on the cheaper one? It is higher wattage, same quality, and it costs less.
