So, I’m thinking to upgrade my gpu and a friend of a friend presents a cheaper than usual card to upgrade with but I’m not quite sure if I should upgrade yet. My current card I have is a Radeon power color turbo duo r9 290x
Here are specs
Brand PowerColor
Series TurboDuo
Model AXR9 290 4GBD5-TDHE/OC
Interface
Interface PCI Express 3.0
Chipset
Chipset Manufacturer AMD
GPU Radeon R9 290
Core Clock 975 MHz
Stream Processors 2560 Stream Processors
Memory
Effective Memory Clock 1250 MHz x 4 (5.0 Gbps)
Memory Size 4GB
Memory Interface 512-Bit
Memory Type GDDR5
3D API
DirectX DirectX 11.2
OpenGL OpenGL 4.3
Ports
HDMI 1 x HDMI
DisplayPort 1 x DisplayPort
DVI 2 x DVI-D
Details
Max Resolution 4096 x 2160
Eyefinity Support Yes
CrossFireX Support Yes
Cooler With Fan
System Requirements Minimum System Power requirement: 750W
Power Connector 6-Pin / 8-Pin
Dual-Link DVI Supported Yes
HDCP Ready Yes
The card being sold fairly cheap is as follows
EVGA GeForce GTX 1070
Base Clock: 1594 MHZ
Boost Clock: 1784 MHz
Memory Clock: 8008 MHz Effective
CUDA Cores: 1920
Bus Type: PCIe 3.0
Memory Detail: 8192MB GDDR5
Memory Bit Width: 256 Bit
Memory Speed: 0.25ns
Memory Bandwidth: 256.3 GB/s
LED Logo: Yes (White)
I got the Radeon card for a bit over 300 around 3 years ago and the evga will be sold to me at 300 if I want to buy it. But I’m unsure as to if I should go with the evga or a different card or just not upgrade at all. Even with all the bad reviews on my current Radeon card mine has worked just fine with minor setbacks but nothing really requiring an mra. What do you guys think?
Here are specs
Brand PowerColor
Series TurboDuo
Interface
Chipset
GPU Radeon R9 290
Core Clock 975 MHz
Memory
Memory Size 4GB
Memory Type GDDR5
3D API
OpenGL OpenGL 4.3
Ports
HDMI 1 x HDMI
DVI 2 x DVI-D
Details
Cooler With Fan
HDCP Ready Yes
CUDA Cores: 1920
Bus Type: PCIe 3.0
