G
Guest
Guest
Hi, all...
I have 2 questions...
1)
I have a FCPGA Celeron 667 MHz CPU. I have been trying to get it to work with a Socket1-FCPGA converter on a Microstar MS-6182 M/B, but all I get is silence. Anyone who has the same motherboard and got the slocket to work?
2.)
I accidentally broke off a pin (VSS at location AN3) on the Celeron while installation. It still works on a Socket370 motherboard, but I was wondering if this will affect the CPU? and can I just use any of the reserved pin and weld it to the missing VSS?
thanks for all your help!
1)
2.)
