Help on Hard Drive!
couple things you could try is pull up disk management to see if your software somehow only made a partition matching the original drive -- see if it recognizes the rest of that hdd space somwhere. Could also try the same thing booting into a Linux LiveCD and using its disk manager to see if that is the case.
http://prntscr.com/9fuk8h now what do I do?
well there the problem, it partitioned your drive. The solution would be to expand or extend the C: drive but it may not let you do that. What are your options when you right click the C: drive in that disk mgmt menu?
I think I got it , I clicked extend volume.
http://prntscr.com/9funr4
