Help on my build
Tran__
Commendable
Mar 25, 2017
42
So its my first time building a PC and I was wondering if my build was good first of all (https://pcpartpicker.com/list/PKjcPs)
but also the my main question was if I needed an HDD and only have an SSD to save a little bit of money. My budget is roughly around 1-1.2k with a red and black theme so if anyone has any ideas to cut down the price it would be much appreciated.
The SSD is higher volume and will last a while. Create a 100gb partition for windows and use the rest for storage. Add a hdd down the line.
Red and black theme overshoots the budget a bit.
CPU: Intel Core i7-7700K 4.2GHz Quad-Core Processor ($343.49 @ OutletPC)
CPU Cooler: CRYORIG H7 49.0 CFM CPU Cooler ($34.89 @ OutletPC)
Motherboard: Gigabyte GA-Z270-Gaming K3 ATX LGA1151 Motherboard ($129.99 @ Amazon)
Memory: G.Skill Ripjaws V Series 16GB (2 x 8GB) DDR4-3200 Memory ($119.99 @ Newegg)
Storage: Sandisk SSD PLUS 480GB 2.5" Solid State Drive ($129.99 @ Amazon)
Video Card: EVGA...
This will last you longer.
Motherboard: Gigabyte GA-Z270M-D3H Micro ATX LGA1151 Motherboard ($119.89 @ OutletPC)
Video Card: EVGA GeForce GTX 1060 6GB 6GB SC GAMING Video Card ($239.99 @ Amazon)
Case: Deepcool TESSERACT SW ATX Mid Tower Case ($38.99 @ SuperBiiz)
Power Supply: SeaSonic S12II 620W 80+ Bronze Certified ATX Power Supply ($49.90 @ B&H)
Operating System: Microsoft Windows 10 Home OEM 64-bit ($88.58 @ OutletPC)
Keyboard: Thermaltake Commander Bundle Wired Gaming Keyboard w/Laser Mouse ($28.99 @ SuperBiiz)
Total: $1194.70
Generated by PCPartPicker 2017-03-25 19:00 EDT-0400
yes but im aiming for a theme colored build and also in the recommended build you suggested it looks like you didnt add an HDD so does this mean i wouldnt really need one?
Video Card: EVGA GeForce GTX 1060 6GB 6GB SC GAMING Video Card ($239.99 @ Newegg)
Case: NZXT S340 (Black/Red) ATX Mid Tower Case ($66.99 @ SuperBiiz)
Total: $1232.80
Generated by PCPartPicker 2017-03-26 01:36 EDT-0400
