Hello everyone.
I'm looking to build my first computer and would appreciate any help. I'm going to do some light gaming (unless of course I get sucked in), programming and perhaps some web development. I would like to keep my budget at around 1000 dollars. Helpful critiques and objective criticisms are always appreciated.
Thanks.
CPU - Intel Core i7-2600K Sandy Bridge 3.4GHz
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115070
Fan - XIGMATEK Intel Core i7 compatible Dark Knight-S1283V REV.W with ACK-I5361 120mm Long Life Bearing CPU Cooler I7 i5 775 1155 and AMD compatible
http://www.newegg.com/Product/Product.aspx?Item=N82E16835233029
Motherboard - ASUS P8P67 (REV 3.0) LGA 1155 Intel P67 SATA 6Gb/s USB 3.0 ATX Intel Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131705
Power Supply - CORSAIR Builder Series CX430 V2 430W
http://www.fatwallet.com/Newegg-coupons/corsair-builder-series-cx430-v2-430w-power-supply-1/
RAM - Kingston HyperX 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Desktop Memory Model KHX1600C9D3K2/8GX
http://www.newegg.com/Product/Product.aspx?Item=N82E16820104173
Hard Drive - Seagate ST310005N1A1AS-RK 1TB 7200 RPM 32MB Cache SATA 3.0Gb/s 3.5"
http://www.newegg.com/Product/Product.aspx?Item=N82E16822148321
Video Card - XFX HD-687A-ZHFC Radeon HD 6870 1GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video Card
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150561
DVD - LITE-ON DVD Burner
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106289
Case - Not too sure. Was looking at this, http://www.fatwallet.com/Newegg-coupons/antec-three-hundred-atx-mid-tower-computer-case/ but it has expired.
This is a grand total of around 920 dollars excluding tax.
Thanks again.
Thanks.
Thanks again.
