Help on my Streaming/gaming build
XLNC ShiFty
40
Well this is my second build and my buget is $2000. My primary use for this pc will be to stream to twtich from my xbox. I also play wow occasionally which is why i put a gpu in there and since im spending this much money i figured i might as well get a decent gpu. So this is where i am at. let me know if you would change any of the components and why or if you would add any. I am also currently using the NZXT Hue to light my current case and it works fine for me personally but i have no experience with other kinds of lighting so if you have better lighting solutions(preferably led strips) then let me know as well.
http://pcpartpicker.com/p/2ejvh
Potential Issues/Incompatibilities
Some Intel X79 chipset motherboards may need a BIOS update prior to using Ivy Bridge-E CPUs.
Asus Sabertooth X79 ATX LGA2011 Motherboard has an onboard USB 3.0 header, but the NZXT LEXA S (Black) ATX Mid Tower Case does not have front panel USB 3.0 ports.
honestly i do no gaming besides world of warcraft and i think the 760 should be able to handle any game i feel like playing on at the minimum of medium which is fine with me because i dont see myself playing any other games on pc than wow. I play console games. Thanks for the advice though.
